Thermostat Will Not Follow Commands - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2009, 06:32 PM   #1
Thermostat will not follow commands
I have a hot water baseboard heating system and I changed from a conventional thermostat to a seven day programmable one.
BIG MISTAKE!
No thermostat setting closes the magnetic zone valve.
I was informed by Honeywell that this thermostat is compatible with my system.
The only way the valve shuts off is when I make the blue and red wires touch.
Does any one have an idea what is going on?
Old Thermostat: White Rodgers Comfort Set (3 wire set) Model Number: IF75-351 with Terminals: B4 - W6 -R5
Boiler: Zoned: 4 zones - AUTOMAG (AA 3/4-14) 40 VAMB
Voltage: 24
NEW THERMOSTAT: RTH7500D - Honeywell - Programmable thermostat
beacu is offline   Reply With Quote
Old 01-06-2009, 07:18 PM   #2
dSilanskas's Avatar
Bad tstat?
dSilanskas is offline   Reply With Quote
Old 01-06-2009, 07:27 PM   #3
No, This is the second thermostat... so I think the tstat is ok...
Old 01-06-2009, 07:29 PM   #4
dSilanskas's Avatar
Missing a jumper?
Old 01-06-2009, 07:40 PM   #5
No, I'm not
Old 01-06-2009, 10:20 PM   #6
fix it
If Honeywell has told you it is compatable they should also be able to tell you how to set it up correctly.
detailedEye is offline   Reply With Quote
Tags
heating
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
