Thermostat Removed Before Wire ID... - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2012, 11:17 PM   #1
thermostat removed before wire ID...
Well, I did it again... I took off the white rogers thermostat model # 1F56w-444 before I realized that I dont know what wire went where? Is there anyway someone can bail me out of this mess? I would be very happy to hear. Thank You in advance. Shame guyhttp://www.diychatroom.com/images/sm...whistling2.gif
dumb a@@ is offline   Reply With Quote
Old 09-17-2012, 11:31 PM   #2
http://wiki.xtronics.com/index.php/T...als_and_wiring
Next time take a pic BEFORE disconnecting anything. :-)
Pirulo is offline   Reply With Quote
Old 09-18-2012, 05:47 AM   #3
Rewards Points: 1,300
How many wires are you dealing with? If I recall, there is a wiring diagram on the back of the mounting plate on those. I think these are a heat/cool thermo? You may need to see which wires are hooked to which on the furnace control board.
danpik is offline   Reply With Quote
Old 09-18-2012, 07:48 AM   #4
Rewards Points: 6,652
Easy fix. Go to where the furnace is, copy what colors go to what terminals, then go to the thermostat and hook same to same. Easy peasy, should be done in less than 15 min's.
Need help connecting Trane TZEMT400 Thermostat; no 'C' wire / 24VAC dinki HVAC 1 04-04-2011 06:28 PM
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 05:28 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
X wire on old thermostat Jellybean HVAC 3 03-30-2008 07:14 AM
