Thermostat Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 10:07 PM   #1
Unhappy
Thermostat problems
recently i upgraded (or rather tried to upgrade) to a new thermostat, i followed the directions and replaced wire for wire. simple i thought, WRONG...i can't get the heat or A/C to operate and the only thing that does work is the blower fan. existing wires are Red, Blue, Brown, Green, White, and Yellow. i have tried various combinations and have fallen way short of achieving success. i humbly ask for help.
the thermostat i am trying to use is a Hunter model #44660, A/C is a Carrier (unsure of age), furnace is also a Carrier (electric pilot light).
any and all help is greatly appreciated.
irish_father is offline   Reply With Quote
Old 10-11-2011, 10:26 PM   #2
Electrical Contractor
kbsparky's Avatar
What were the wires on the old one labeled?
How were they connected?
-KB
Old 10-11-2011, 10:30 PM   #3
it was a one for one swap. the wires were the same. (or so i thought, now i am honestly at a total loss)
Old 10-11-2011, 10:45 PM   #4
Missouri Bound's Avatar
Everyone here is happy to help. I suggest you put this in the HVAC section for help from people experienced with thermostat issues.
Old 10-11-2011, 10:46 PM   #5
Check connections at or inside your furnace. If it's gas fired your connections should be as follows:
R- R. 24v
W- W heating
G- G. Fan
Y- Y. A/C compressor
This is where you need to check at furnace connections. In my experience both blue and brown have been used as common as well as not used at all.
thestig3 is offline   Reply With Quote
connecting a 4 wire SP thermostat to a 2 wire system wiichkin Electrical 4 08-15-2010 01:35 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
FAULTY THERMOSTAT!!! What the He.... Krazecon HVAC 11 02-12-2009 04:26 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
mini fridge thermostat problems furniture_guy Appliances 1 12-19-2006 06:55 AM
