#1 |
Thermostat issue, need help
OK, here is the issue I have. I have two zones for my heat/ac. I have an oil boiler, an a/c unit outside and what i believe to be hydro heat as well (there are copper pipes that run through the forced air portion of the blower).
One zone (main floor) has a nice programmable LUX thermostat. The upstairs zone has an old school dial thermostat that is obviously not programmable, causing over-usage or heat and/or A/C. I opened up the thermostat upstairs and it has two main wires coming out of the wall. Attached to the thermostat were 3 wires, R, Y, W. The W and Y come from 1 larger wire and the R comes from the 2nd larger wire with two open wires taped off. I am not sure how to connect the new LUX programmable thermostat. The 3 wires that were being utilized previously are labeled. The other 2 are not labeled. They are white and black in color. The R was red in color. SO, I would like some assistance if anyone can help in trying to install this 2nd thermostat. I would like it if the upstairs zone was a completely separate zone. Right now i believe when you turn off the thermostat downstairs, it turns off the ability to use the "dial" thermostat upstairs. Thanks. Jon |
#2 |
Average Joe/ex-Navy IC3
If you want to find out if there are wires from the downstairs thermostat, to the upstairs, you are going to have to do a continuity test, or get a fox & hound set.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| Display Modes | |
| Replacing old Honeywell thermostat with new Honeywell thermostat | optimizer | HVAC | 13 | 04-20-2011 07:22 PM |
| Installing New thermostat need help | effusion_01 | HVAC | 18 | 03-01-2011 06:09 AM |
| double pole thermostat for kickspace heater | lee12 | Electrical | 3 | 12-09-2010 01:52 PM |
| connecting a 4 wire SP thermostat to a 2 wire system | wiichkin | Electrical | 4 | 08-15-2010 02:35 PM |
| Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System | TekGamer | HVAC | 0 | 07-10-2010 12:58 AM |
