Thermostat To Furnace Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-03-2011, 11:34 AM   #1
thermostat to furnace wiring
I have a model GH6-100T lennox furnace. The black and white wires from the thermostat to the furnace were disconnected and I need to determine which terminals on the line box and gas flow through box on the furnace I should connect them to.
Craig66 is offline   Reply With Quote
Old 11-03-2011, 01:24 PM   #2
If possible, you should contact Lennox and see if you can get an installation manual form them or from their web site. This would include wiring instructions for THAT specific furnace...
Billy_Bob is offline   Reply With Quote
Old 11-03-2011, 01:57 PM   #3
Retired from the grind
Rewards Points: 6,652
Man, that thing is accent. I would not even attempt to use a unit that is over 50 years old, due to you never know what kind of problems there are with it (ie cracked heat exchanger, parts no longer available). You will never be able to get anything from Lennox, due to how old that unit is.
http://search.yahoo.com/search;_ylt=...&cop=&ei=UTF-8
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 06:50 AM
Wiring new Thermostat to new furnace hartkem HVAC 7 11-11-2008 07:09 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 07:04 AM
New Thermostat and Furnace Not Working Right Vegas Resident HVAC 1 12-06-2007 06:42 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
