Thermostat To Control An Additional Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 12:07 PM   #1
Question
Thermostat to control an additional motor
Hi everyone,
Whenever my thermostat instructs the a/c or furnace to operate, I want it to also open or close a specific duct via a small electric motor that is attached to the duct.
1. What size electric motor can I use?
3. How do I wire this electric motor to the thermostat?
4. How do I control the electric motor so it opens and closes the duct. Ideally it will only use electricity while it opens or closes the duct as upposed to using electicity to constantly keep the duct open or closed. I assume this will also require some kind of switch?
Thanks for your help.
tacklebuster is offline   Reply With Quote
Old 06-14-2011, 07:40 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Instead of making one, probably your easiest option is to check with your local HVAC supplier for a zone damper in the size you need. They’re made for what you want to do.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
tacklebuster (06-28-2011)
Old 06-15-2011, 06:05 AM   #3
Lic Elect/Inspector/CPO
Honeywell makes a 24 volts motorized damper.
The motor opens the damper and a spring closes
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
Carrier a/c condenser fan motor still running slowly after thermostat is satisfied GetYourShineBox HVAC 18 06-14-2013 11:26 AM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Induction motor and thermostat dklank HVAC 9 05-03-2011 10:02 PM
Additional Wall Switch to control light tiame Electrical 6 07-03-2009 11:54 PM
Additional Blower Control Lawrence Coppar HVAC 6 06-12-2009 05:53 AM
