Thermostat Assist Please. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 09:19 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Thermostat assist please.
I just pulled an old thermostat out of the wall because the handle was broken on it. Got a new one to put in there, and had to put in a bigger box for it.
My problem now is that the old t-stat wasn't labelled line or load. The new one is labelled, and i have 3 black wires in this box and I didn't know which one was the line wire.
I separated them and went and flipped on the power, now all 3 black wires are hot.
What gives?
Journeyman Plumber
Old 04-07-2012, 09:25 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
How are you metering the wires? To ground? To the white?
You will need to meter the blacks to ground.
Old 04-07-2012, 09:27 PM   #3
Doing it myself
Alan's Avatar
Voltage detector.
I guess I should take voltage readings on each of the lines?
Journeyman Plumber
Old 04-07-2012, 09:28 PM   #4
k_buz's Avatar
The other way to do it is to keep the blacks separated, and separate all the whites (with the breaker off). Then turn on power and meter black to white.
Old 04-07-2012, 09:28 PM   #5
k_buz's Avatar
Are the heaters 120 or 240V?
Old 04-07-2012, 09:34 PM   #6
Doing it myself
Alan's Avatar
I'll check the heaters one minute.
The voltage from black to ground reads 117V on each one.
Journeyman Plumber
Old 04-07-2012, 09:35 PM   #7
Missouri Bound's Avatar
Sounds like a single pole stat on a 240v circuit.
Do you want it your way or the right way?
Old 04-07-2012, 09:43 PM   #8
Doing it myself
Alan's Avatar
The heaters have no data tag on them. I opened them both up where the connections are, and there's nothing to say 240v or 120v
So I have 3 wires in the box, and two heaters.
The thermostat was a single line break, so what i'm seeing on the wires is the voltage feeding back through the heater on one leg on two wires, and the other leg is the hot incoming to the thermostat?
Journeyman Plumber
Old 04-07-2012, 09:43 PM   #9
k_buz's Avatar
Turn off power.
Separate the whites (leave the blacks separate)
Turn on power
Meter between black and white
You should only have power on one set of wires
Mark that wire with a wirenut or something
Turn off power
Splice the whites back together
Put the wire with the wirenut on the line side and splice the other two to the load side.
Old 04-07-2012, 09:44 PM   #10
k_buz's Avatar
yes...
Old 04-07-2012, 09:45 PM   #11
Doing it myself
Alan's Avatar
Turn off power.
Turn on power
Turn off power
Thanks.
Journeyman Plumber
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
