Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2007, 09:45 AM   #1
Darylh's Avatar
Thermostat
I want to install a wall Thermostat to controll my construction heater in my shop. What I thought about was having the thermostat controll the plug outlet. So exactly what kind of Thermostat would I need for a 40 amp plug
Darylh is offline   Reply With Quote
Old 01-07-2007, 09:49 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Not sure I've ever seen one rated that high. I'm not saying it isn't made, it's just not a common item.
It will be MUCH easier to find the control circuit in the unit and use that with a t-stat. In fact, most units are designed to accept a t-stat somewhere in the control circuit. This will be a simple two-wire hook up.
Check the instructions to see what they recommend.
Old 01-07-2007, 10:24 AM   #3
Darylh's Avatar
Thanks Speedy Petey I will check the amps on this again and maybe a few pics of the wiring. The heater is about 5 years old and there is no paper work on it so i will get back to you on this.
Old 01-07-2007, 10:29 AM   #4
Most home depots sell 110v cords with thermostats already installed.Is this gas heater or electric.
trollmastergeneral is offline   Reply With Quote
Old 01-07-2007, 10:53 AM   #5
Google is a wonderfull thing. Try the part number and watch the magic.
jwhite is offline   Reply With Quote
Old 01-07-2007, 10:55 AM   #6
A 40 amp 120 volt cord, (or even the recepticle, and breaker) would be a speciality item. They do make them, but I doubt you will find them at the big box stores.
Old 01-07-2007, 11:38 AM   #7
Well I guess I was thinking that it was highly unlikely it was a 40 amp rating .If that is the case you probaly have to special order like jwhite said
Old 01-07-2007, 03:41 PM   #8
You'd be surprised. Some of these electric shop heaters are quite large. The heater the OP has is probably a 7-8kw unit.
Old 01-07-2007, 05:28 PM   #9
Darylh's Avatar
Okay ooppss the Heater is 20 amps/240 volt. The heater is wired to a 30amp 2 pole breaker. My thermostat is rated up to 22 amps/270volts.
1st--- should I change this breaker to 20amp 2 pole and can I use my thermostat
Old 01-08-2007, 04:45 AM   #10
dont change the breaker. Make sure that no 10 wire was used.
everything else is fine.
Old 01-19-2007, 08:55 AM   #11
Darylh's Avatar
Thanks for the help everone. I hooked up the thermostat and oh what a blessing. Just to make sure I did this right here is a pick of what I did.I used the black to tie the TS in .
Old 01-19-2007, 09:08 AM   #12
Hi there, I'm considering doing this as well. I can't make heads or tails of your sketch though. Did you take any pictures of the install inside your heater?
Also, what brand/model thermostat did you use that is rated for 270V and 22AMPS?
Did you have to run #10 wire (2 wires I guess) from the thermostat location to the heater?
timg is offline   Reply With Quote
Old 01-19-2007, 09:22 AM   #13
Darylh's Avatar
Hi i am off to work and will post tommorow morning.
Old 01-19-2007, 09:37 AM   #14
240 volt line voltage thermostats are available almost anywhere that sells electrical supplys or HVAC equiptment.
Since you still need a disconnect at or near the heater, you will notice that Darylh wired the thermostat a head of the recepticle.
All you need to do for this type of control is break one leg of the 240 volts going to the heater, through the thermostat.
You will need to run the same size wire as you would for any other part of the circuit. So if the rest of the circuit is 10 wire, you need 10 wire for the switch loop to the thermostat as well.
Old 01-19-2007, 09:59 AM   #15
Thanks for the reply. That explains it perfectly.
Tim
NOMA Thermostat brobinson68 HVAC 5 01-17-2007 02:36 PM
Noma Thermostat vs Old Thermostat diywoman Electrical 2 01-04-2007 01:02 PM
Thermostat question ctown HVAC 7 12-05-2006 03:46 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
