Thermal Fuse For Convection Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2008, 07:32 AM   #1
Thermal fuse for convection heater
Hi.
My Convector heater (Delonghi DH15, 110V, 750/1500W with fan) need to replace the thermal fuse(one time cut-off type).
The problem is the marking on the fuse is too dark to read, manufacturer does not supply the parts anymore.
Any one have idea what cut off temp should it be?
I believe any convector heater with similar specification should use similar fuse with temperature range.
TJSHAO is offline   Reply With Quote
Old 12-27-2008, 09:37 AM   #2
Rewards Points: 204
Take the thermal cutoff to a local electronics store and see if they can match it. Its not a fuse. Does it look like a diode or resistor? Barrel shaped, with a stiff wire coming out of each end?
Old 12-27-2008, 01:23 PM   #3
Thanks JV, I think we are on the same page, 'thermal cutoff', also known as 'thermal fuse', cut off at certain temp and its one time use like 'fuse'.
Yes its a bullet shaped like diode but the problem is similar temp range cutoff are identical in shape and size, can't just fit simply from size and shape......
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
Blown fuse in Control Panel of Carrier Heater jacksup HVAC 3 02-26-2008 05:02 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
