Theres Some Bare Feeder Before Main Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 11:23 AM   #1
Rewards Points: 270
Theres some bare feeder before main breaker
Maybe 1/2" of bare feeder before the main breaker. Anything I can do about this other than replacing the feeder. Like cover it with something without touching it?
How do they go about replacing a feeder? How do you get these lines shut off? From the pole?
pcampbell is offline   Reply With Quote
Old 01-13-2009, 12:23 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I wouldn't do anything... why would you want to?? The only technical issue is the wire isn't at the correct strip length. But on main lugs this isn't unusual and doesn't pose much of any safety hazard. Just keep bare ground wires away as they should be.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-13-2009, 04:12 PM   #3
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
No big deal.
Magnettica is offline   Reply With Quote
Old 01-13-2009, 04:23 PM   #4
Rewards Points: 270
Thanks...I jumped it while pulling out an old wire once. I guess in retrospect, I could have cut the old wire so I would not have had to pull the wires past the feeders!
Old 01-13-2009, 04:51 PM   #5
Magnettica's Avatar
Rewards Points: 150
And that's really the only time there's really any danger. Because even if the feeder was stripped to fit the lug just right, the lug is still exposed no matter what. Anything more than 1/2" from the lug is unprofessional on the installers part.
Main Circuit Breaker Test lthomps222 Electrical 16 11-07-2010 04:40 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
Main disconnect breaker coyote556 Electrical 9 08-01-2007 04:52 AM
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 04:31 PM
