Is There A Wire Adaptor For Lugs In Sub-panel - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2012, 05:03 PM   #1
Is there a wire adaptor for lugs in sub-panel
I am in the process of rewiring my house and I plan on using a
sub-panel ( Eaton cpl112 125 A ) to feed the kitchen and dinning area.
We have a gas stove so there will not be any breakers above 20A in the
sub-panel.
I am planing on using the 40A ( #8-3 with ground wire ) that use to feed
the electric stove to supply the sub-panel with the original 40A breaker
in the main 200A panel.
The problem I have is that the min wire size for the lugs in the sub-panel
is #6 wire according to the label in the sub-panel, and I am trying to use
#8 wire, so how do I get around that ?
Take #8 wire strip the end fold it over and stick in the lug ?
The inspector probably wont pass that.
Use one of these copper lugs from Lowe's
http://www.lowes.com/pd_47513-12704-...ductId=3370334
its rated for #6 down to #14 put the wire #8 wire in the clamp area
and the spade end in the sub-panel lug.
Get a short piece of #6-3 cable and use solder/wire nuts/crimp and shrink tube to get the wire size up to #6 in the sub-panel, not sure if we are allowed to have joints in the panel in my area ( Ontario Canada ).
Or is there some other way ?
Thanks for any replies.
Whome is offline   Reply With Quote
Old 10-14-2012, 07:00 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
In the states you could use wire nuts to connect a short piece of #6 to the #8, but I've heard wire nuts inside panels are allowed in Canada.
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
Wire size to sub panel zom Electrical 4 06-03-2011 09:46 AM
Passing wire to another panel theatretch85 Electrical 5 09-20-2009 11:09 PM
Panel ground and wire size tns1 Electrical 25 09-18-2009 02:53 PM
Future wire in panel? wease Electrical 20 05-10-2009 03:28 PM
