Is There Such A Thing As Switch For Rg-6 Cable ? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 10:56 AM   #1
Rewards Points: 1,062
Question
is there such a thing as switch for rg-6 cable ?
i am teeing cable off in the main unit of my house and want to provide it to the basement apartment only if the tenant there pays extra, otherwise i flip the switch. i would like it to be like a light switch. i know i could do it with just (un)twisting F-connectors but that would not be as elegant.
Old 04-28-2010, 12:57 PM   #2
joed's Avatar
Rewards Points: 12,362
Yes. They are called A/B switches. Generally used to switch two different inputs to a TV (cable and antenna for example). Just leave one input empty and it will be like an on/off switch.
Here is one sample. There are many others.
Old 04-28-2010, 02:20 PM   #3
. . .elegant
You're about to find out what elegance costs.
http://www.google.com/search?hl=en&s...=&oq=&gs_rfai=
You want SPDT.
Old 04-28-2010, 02:36 PM   #4
Rewards Points: 1,016
How often are they going to be moving in/out or not paying and you terminate their service? Seems just unplugging them would be good...
But, yes there are switches - from simple and cheap to spiffy and more expensive.
Old 04-28-2010, 03:29 PM   #5
thanks all but i was looking something that integrates into drywall like a light switch with a switchplate cover. this little cable switch like looking thing does not because it would involve cable dangling outside the wall, which is what i am trying to avoid.
Old 04-28-2010, 05:08 PM   #6
It's hard with coax because the geometry determines the characteristic impedance, which must match that of the system.
You can go with miniature cable, the type that takes SMB connectors, but the cable loss is high at TV freqs. Then you'd need a booster amp, and have to worry about noise figure, etc.
It's possible that what you want doesn't exist at any price, unless you build it yourself.
High frequency printed circuit board design is not easy.
Old 04-28-2010, 06:35 PM   #7
joed's Avatar
Never seen one that looks like a light switch. Good luck.
Old 04-28-2010, 06:44 PM   #8
Take this, put it in a low voltage trim ring
Turn it sideways & mount it securely to a light switch face plate
Superglue something to that moveable switch that will fit the little knob that mounts on a dimmer
Best I can do
Old 04-28-2010, 10:36 PM   #9
Just call me Andrew
Rewards Points: 1,020
It also may not be legal to charge a tenant to tap into your cable service. Shouldn't they get their own service?
Andrew
secutanudu is offline   Reply With Quote
Old 04-28-2010, 10:51 PM   #10
Union Electrician
goose134's Avatar
I actually let my tenant use the direct tv hookup for nothing. Because the installation was two rooms, one service it happened that the rooms were on different floors. I like to think of it as an incentive in a very competitive rental market.
goose134 is offline   Reply With Quote
Old 04-28-2010, 11:18 PM   #11
Truth. If the apartment you speak of has a separate power meter/panel any cable company will consider the apartment as independent of you and require a separate cable account. Having a tenant pay you to share your cable is considered an illegal connection, and yes, cable companies can and do press charges for this.
However, the only way to do what you speak of and maintain signal integrity would be to barrel the line in the wall, put up a mud ring an a blank cover. When you want to disconnect it take the line to the apt off, leave the barrel connected to the live line. An unterminated F connector will change the impedance of the system and can cause ingress/egress.
mgarfield is offline   Reply With Quote
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Switch now controls large area... froddan Electrical 5 12-06-2009 10:04 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
