Old 03-18-2011, 12:42 PM   #1
Question
is there such a thing as fishtape lubing?
my fishtape is getting rusty, seems like, and it's hard to reel it back in. can i lube it or do something else?
Old 03-18-2011, 12:59 PM   #2
Licensed electrician
WD-40 would be a good idea.
Old 03-18-2011, 01:08 PM   #3
Experienced
Jackofall1's Avatar
Pull it out and wipe it down with an oily rag.
Old 03-18-2011, 01:15 PM   #4
nap
You talking to me?
nap's Avatar
sure, get a stainless steel tape
just pull it all the way out and use some wd-40 on a rag and thoroughly wipe it down. You might need to take some steel wool to it if the rust is bad.
if you don't use it quite regularly, be sure you unreel it all the way and wipe it down with wd-40 before storing it. You need to remove the dirt (that holds moisture) and water.
Narrow Utility Sinks - Is there such a thing? mr_trotta Plumbing 17 04-11-2012 05:10 PM
Fishtape refill canadaclub Electrical 3 02-09-2010 08:55 PM
what is this 'cutting in' thing I'm hearing about in paint threads? joeyboy Painting 13 01-03-2008 03:34 PM
lost power to 1 thing in 4 different places... ManMythLegend Electrical 31 12-19-2007 01:57 PM
Is there such a thing? wiscborn Plumbing 6 06-29-2007 03:19 PM
