Is There A "spacer" That Goes Behind A Switch Plate? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 09:44 PM   #1
Rewards Points: 1,584
Is there a "spacer" that goes behind a switch plate?
I have a two gang box that is quite shallow. It used to have two toggle switches but I have switched out two dimmer switches and of course those take up more room.
With the wires and nuts behind the switches I have no choice but to take out the flat mud ring and replace with a 1/2" raised mud ring which gives enough room for the dimmers now but the switch plate is 1/2" off the wall.
Is there some sort of a spacer I can use to fill this gap?
miamicuse is offline   Reply With Quote
Old 07-19-2012, 09:47 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Can you change the box out to a deeper one or is the thickness of the wall hindering that option, otherwise, you could make a nice picture frame out of wood to the thickness required.
Old 07-19-2012, 10:04 PM   #3
I can't, behind it is a concrete wall so unless I start to tear out more sheetrock and bring out my hammer and chisel it's not going to work.
Old 07-19-2012, 10:08 PM   #4
E2 Electrician
Then I would just make a spacer out of wood with a decorative edge to jazz it up a touch.
Old 07-19-2012, 10:29 PM   #5
Can I roll up some play dough into the shape and size of a pencil, press it into the space all the way around, smooth it off and paint it?
Old 07-19-2012, 10:33 PM   #6
E2 Electrician
Go for it!
Old 07-20-2012, 12:27 AM   #7
Missouri Bound's Avatar
You can do whatever you want in your house. If you ever want to sell it.....that's a different story.
Do you want it your way or the right way?
Old 07-20-2012, 12:30 AM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Wiremold Extension Box
Old 07-20-2012, 01:09 AM   #9
Rewards Points: 192
Here is a link at HD. You may need to reinstall your original mud ring then add this.
http://www.homedepot.com/Electrical-...&storeId=10051
bcgfdc3 is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
confused on switch replacement fullpint Electrical 6 07-11-2011 09:39 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
How to choose light switch styles (for 2 and 3 gangs) jelly Electrical 2 06-08-2008 02:52 PM
