Is There A Limit To How Many Romex Can Go Through Through One Hole? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 08:21 AM   #1
Is there a limit to how many Romex can go through through one hole?
is there a limit to the number of 12/2, 14/2 or combination of the two, that can run through one hole in a floor joist?
For my project, I need to run three 12/2 through one hole, it looks large enough to pull through without forcing it, probably a 3/4" hole...
On the same subject how about 3 wire, does it make a difference if the hole is big enough to get the wire through without damaging it?
toobhed is offline   Reply With Quote
Old 08-06-2011, 09:41 AM   #2
Lic Elect/Inspector/CPO
You can 3, 14-2/ 12-2 or combination thru the floor joist. I limit 3 romex wires thru a hole. When going thru a fire rated assembly such as a fire stop, you are limited to only 3 romex cable, do to derating of the conductors.
Regular floor joist ther is not that problem, even though some inspectors will say that more than 3 would be bundling.
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
toobhed (08-06-2011)
Old 08-06-2011, 10:10 AM   #3
That's good news, need to run one 12/2 through existing hole, saves me a lot of hassle.
Thanks njmarine!
Old 08-06-2011, 10:53 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
You can run up to four 14/2 or 12/2 cables through a hole. You can also run four 14/3 or 12/3 cables through a hole. But watch mixing 3 and 2 wire cables in the same hole.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 10:57 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 02:53 PM
Cutting out a hole on a stainless steel sink...pics Goldglv General DIY Discussions 14 02-28-2010 11:04 PM
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 06:55 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
