Is There A Limit? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 01:26 PM   #1
Is there a limit?
I need 5 - 12 AWG wire nutted in a junction box. Is that too many? What color is that nut?
Joe Willie is offline   Reply With Quote
Old 05-17-2011, 01:30 PM   #2
I=E/R
a7ecorsair's Avatar
Your wire nut package should have a listing of how many wires are supported.
a7ecorsair is offline   Reply With Quote
Old 05-17-2011, 03:53 PM   #3
Next Time...New Build
Rewards Points: 150
I believe the max a red-winged nut can handle is 5 - #12s. I recently did this but used the Big Blues. As mentioned, check the package, it will tell you the maximum and minimums of each size.
RickyBobby is offline   Reply With Quote
Old 05-17-2011, 04:08 PM   #4
Thanks, I saw 5-12's on a pack of reds...I wanted to hear from experience. I'll get a couple of both.
Old 05-17-2011, 05:41 PM   #5
joed's Avatar
Rewards Points: 11,516
Depends on the type of nuts. This type the red one can hold up to 5 #12.
http://www.idealindustries.ca/produc.../wingtwist.php
Trane limit switch mikethe ductman HVAC 7 01-18-2012 11:46 PM
Blower fan won't turn off - limit switch replaced Laplacian HVAC 4 02-14-2011 12:55 PM
Furnace limit switch Deereman HVAC 1 12-11-2010 11:56 AM
AMER STD open high limit sei564 HVAC 6 03-16-2010 09:22 PM
Replace secondary limit switches on Lennox 80MGF? dawg89 HVAC 1 02-05-2010 07:31 PM
