Is There An Electrician Handy - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 07:22 PM   #1
Rewards Points: 1,662
Is There an Electrician Handy
I've found electrical work to be rather shocking at unannounced times so advice to myself is to ask the experts.
I have this push pull switch I'd like to use on my table saw that has a 120 volt single phase half horse motor. The switch reads -- Rating, 75 amps., 2-28 volts, DC - - sorry about the pic size but that's all the information on it. Will this work for my 120V half horse AC motor?
Old 02-14-2013, 07:25 PM   #2
Electrical Enthusiast
Rewards Points: 504
Looks like it's only good for lower voltage DC, so it probably wouldn't be the best idea.
Kyle_in_rure is offline   Reply With Quote
Old 02-14-2013, 08:04 PM   #3
Rewards Points: 6,652
You answered your own question, by reading what the switch body states on it, as to what kind of circuit that it can be used on. Also, doubt that it is 75 amps, but 3/4 of one amp, since it is only good for a 2-28 volt Direct Current circuit.
The Following User Says Thank You to gregzoll For This Useful Post:
Speedy Petey (02-14-2013)
Old 02-14-2013, 08:10 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Sorry to sound rude, but you didn't even have to ask this question. You had your answer when you read the info on the switch.
That is an automotive/vehicle switch. Vehicles are typically 6-24V DC, hence the switch's rating.
Old 02-14-2013, 08:14 PM   #5
It is 75A. I was surprised to see this also.
http://www.oreillyauto.com/site/c/de...0212&ppt=C0335
Old 02-14-2013, 08:26 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
Just so you understand, it's the material the contacts are made out of the determines the voltage rating. The arc you get with DC is different than AC....hence, the way the contacts are made and what they are made of is different.
Case in point.....using a relay intended for AC in a DC application can result in welded contacts very quickly.
ddawg16 is online now   Reply With Quote
Old 02-14-2013, 09:20 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,486
It's probably 7.5 amps.
So no I would NOT use it for 120v ac !
your motor will need about 400w.
So you need a switch rated for minimum 4 amps at 120v.
Taking into account start up surge,
I would use a 10amp switch minimum.
dmxtothemax is offline   Reply With Quote
Old 02-14-2013, 11:24 PM   #8
" Euro " electrician
frenchelectrican's Avatar
The switch you posted in the photo will not work with your useage.
You will need a 120 or 240 volt rated switch which it will be simauir to that and it have to be rated minuim of 10 amp.
Some of the big box store may carry this type of switch in correct voltage range so it should be there.
Merci,
Marc
Old 02-16-2013, 02:08 AM   #9
Not A Licensed Pro
outlet box + your common everyday 15A wall light switch? $4 total?
or ... a foot switch
what exactly are you trying to 'rig up' with the push pull? to be able to bump the switch with your knee to turn it off?
kevinb70 is offline   Reply With Quote
complicating-updating new box for client, electrician messed it up-pics included Kraze Electrical 29 11-18-2012 09:14 PM
Licensed Electrician or Not? taras1 Electrical 10 04-29-2011 06:23 PM
Do I Need to Call in a Electrician to Check This Work? taras1 Electrical 6 12-13-2010 05:07 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 08:39 AM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 07:07 PM
