Is There A Distinction Between "in-wall" Vs "through Wall" ? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2009, 07:40 AM   #1
Rewards Points: 179
is there a distinction between "in-wall" vs "through wall" ?
hanging plasma on the wall. the outlet and cable are several feet from the position where i'd like to place the TV. The room BEHIND the wall where i'd like to hang the TV has an outlet and cable just 3 feet away.
Yes, in a perfect world i would split off another outlet and put a receptacle behind the TV, etc etc, but this DIY-er can't do it on his own without opening up the sheetrock and making a big project out of it.
I am considering just making a 3 inch opening in the wall behind the TV and "poking" the power and TV cable through the wall and into the outlet a couple of feet away in the other room. The other room is just an office and i don't care if those wires are hanging down the wall.
This isnt a case of me "fishing" multiple feet of wire behind a wall, i'm talking literally poke it directly from one room into another.
I know its sloppy, but am i violating a specific code that says wires such as TV type power and cable wires cannot be passed through walls? The total amount of wire between walls would be 4 inches.
thanks..
windowguy is offline   Reply With Quote
Old 02-27-2009, 07:48 AM   #2
the Musigician
DangerMouse's Avatar
i don't THINK it's a violation, but i may be wrong. but the open wall is an invitation to possible insects/rodents getting in. it's like running an extension cord around a corner to another room. heck, i should think it's even safer! but just wait....if i'm wrong, someone will let us know shortly, i'm sure.....
DM
Old 02-27-2009, 07:51 AM   #3
Rewards Points: 2,350
Sleeve it with a piece of PVC.
Old 02-27-2009, 07:56 AM   #4
the Musigician
now there's a good answer!
i'd go a step further and get hollow caps/rings to glue on each side too.
keep out the riff-raff....
DM
Old 02-27-2009, 08:02 AM   #5
Chicago, IL
Michael Thomas's Avatar
400.8 USES NOT PERMITTED. Unless specifically permitted in 400.7, flexible cords and cables shall not be used for the following:... (5) Where concealed by walls, floors, or ceilings or located above suspended or dropped ceilings.
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Michael Thomas is offline   Reply With Quote
Old 02-27-2009, 08:07 AM   #6
Registered User
Termite's Avatar
In my opinion, the intent of that code is to prevent people from running those cords vertically or horizontally IN walls, concealed. Going directly through the wall...Albeit sloppy...Wouldn't get my hackles up.
Old 02-27-2009, 08:09 AM   #7
Chicago, IL
OK, looked it up (last cite was from memory), it's 400.8(2) uses not permitted.... (2) Run through holes in walls, structural ceilings, suspender/dropped ceilings, or floors.
Old 02-27-2009, 08:19 AM   #8
I'd sleeve it in conduit, oversized - 2" min
Since the cord will not be concealed I do not see a code issue
As long as you are going straight thru the wall & not angling down to the outlet
A friend actually cut a hole in a wall & mounted a reg CRT TV in the closet. The screen was flush with the wall, looked very nice
Old 02-27-2009, 08:21 AM   #9
Rewards Points: 179
i like the PVC idea, i'll just cut the hole the same size as the PVC ring. I'm probably going to do this anyway, code or not, if i ever sell the house i'll just pull the wires back through and run everything along the floor for an inspection. (and the wall is very easy to patch).
good ideas.. thanks guys.
Old 02-27-2009, 08:26 AM   #10
Chicago, IL
See response #7 above
Old 02-27-2009, 08:28 AM   #11
Rewards Points: 876
Exactly my thought.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-27-2009, 08:33 AM   #12
the Musigician
michael, is that specific to house wiring, or does that include appliance cords?
i've seen holes in kitchen cabinets to plug in appliances.
and for sure, use at least 2" ID pvc, you need to easily pass plugs through.
if you went 4", that allows easy viewing of the entire wire, so wouldn't that be NOT concealed?
DM
Old 02-27-2009, 08:33 AM   #13
If it's sleeved then its no longer a hole in the wall
Its a short section of conduit
It states flexible cord, doesn't specify extension cord or appliance cord
DW cord is many times passed thru to sink area, same with the microwave
But then its a hole in cabinet, not a wall
Old 02-27-2009, 08:37 AM   #14
Rewards Points: 179
you guys are BRILLIANT.
Old 02-27-2009, 08:37 AM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 388
I'd say not allowed, as stated by Michael.
jbfan is online now   Reply With Quote
