Is There A Device That Can Measure The Actual Load At Your Counter? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 05:43 PM   #1
Is there a device that can measure the actual load at your counter?
Greetings:
Is there a device that can accurately measure the actual load at the counter where the main panel and a single 30A circuit breaker is? I would like to know precisely at what amp value the circuit breaker tripped.
Your help is greatly appreciated.
njchen24 is offline   Reply With Quote
Old 08-07-2011, 07:35 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,858
Where are you located? I don't think you're in the U.S. Can you update your profile with your location?
mpoulton is offline   Reply With Quote
Old 08-07-2011, 11:40 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,098
Clamp on amp meters are readily available,
the price depends on the quality,
http ://www.google.com.au/searchtbm=isch&hl=en&source=hp&biw=1280&bih=630&q= clamp+on+amp+meter&gbv=2&oq=clamp+on+amp+meter&aq= f&aqi=g1&aql=&gs_sm=e&gs_upl=2344l7750l0l9094l18l1 8l0l7l7l0l500l2578l2-1.4.1.1l7l0
If you paste this into your browser, you can see one.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
GottaFixIt (08-09-2011)
Old 08-07-2011, 11:45 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
If you want to monitor the load over a length of time you will need a chart recorder.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-08-2011, 05:18 PM   #5
I am located in NJ. Profile has been updated.
Old 08-08-2011, 05:22 PM   #6
I paste the above link into my browser and see my post. What price range should I focus on? Let say that there is a $40 and $80, which one best fit my application?
Old 08-08-2011, 06:49 PM   #7
As I live on the other side of the world ( down under )
I am not familair with your retail enviroments,
If you look around your area, perhaps do a google search
you will find there are probably many available,
If you find too many, narrow them down,
then ask for help with the final choice.
Old 08-08-2011, 08:04 PM   #8
Can a chart recorder measure the load right the moment that the circuit breaker triped? Can you recommend one?
Old 08-08-2011, 08:19 PM   #9
Experienced
Jackofall1's Avatar
A chart recorder on the less expensive end is between $2,000 & $3,000, an amp probe / clamp-on will not give you an accurate reading of amps at the moment a breaker is tripping, especially if the load is momentary.
What is it you think is drawing to much current and tripping the breaker?
Mark
Old 08-08-2011, 08:37 PM   #10
electures's Avatar
A chart recorder will chart thecurrent over time. Check Ideal, Amprobe, Klein Tools to name a few.
Old 08-08-2011, 09:23 PM   #11
Master Electrician
Rewards Points: 3,678
Mark
Is it possible to change Circuit breaker to Buss fuse socket type?
Remember this thread?
brric is online now   Reply With Quote
Old 08-08-2011, 09:40 PM   #12
Experienced
Jackofall1's Avatar
Originally Posted by brric View Post
Interesting, very interesting indeed. Now I understand completely. Could be a loose connection to the main breaker thats where I would first look.
But AC units cause a fair amount of inrush when the compressor cycles.
The Following User Says Thank You to Jackofall1 For This Useful Post:
Old 08-08-2011, 09:53 PM   #13
Some multimeters(with clamps) have a hold feature that will register the highest reading. Not really ideal for long term monitoring, but if you know what's causing it, you can check the high load that way.
What are you running that's blowing the 30a circuit?
Often its a poor connections somewhere that causes a voltage loss and blows the breaker. I'd check the voltage at the load as well.
GottaFixIt is offline   Reply With Quote
Old 08-09-2011, 07:38 AM   #14
Master Electrician
[quote=GottaFixIt;703276].
The whole apartment is on one 30 amp feeder.
The Following User Says Thank You to brric For This Useful Post:
Old 08-09-2011, 08:22 AM   #15
Well that explains it
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Help 30 amp Load center for my HID lights and miscellaneous Mont@n@ Electrical 9 03-06-2010 12:49 PM
More Accurate Load Calculation zootjeff HVAC 9 12-14-2009 01:06 AM
Wire sizes based on actual connected load BigJimmy Electrical 7 08-21-2007 09:30 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
