Originally Posted by Arketh
The other fact is that Range plugs and Dryer plugs are not the same pin out, due to the different current ratings.
It would not matter what kind of (male) pin out arrangement was used where the adapter was internally fused for 15 amps, or could be 20 amps when equipped with a duplex (female) receptacle set fed by one of the hot lines.
Actually there is a disadvantage using this adapter behind a stove, e.g. when converting an electric stove to gas. If the internal fuse blew (or an internal breaker tripped) it would be necessary to move the stove to reset the adapter.
