01-02-2013, 05:48 PM
#1
Is there a converter to plug into a 220v Dryer outlet so I can use it as 110?
Looking for a converter to convert a 220v Dryer outlet to be used as 110v without rewiring. Anyone know if this can be done?
01-02-2013, 05:52 PM
#2
Not safely or legally.
The Following User Says Thank You to Oso954 For This Useful Post:
01-02-2013, 06:02 PM
#3
A "Handy Husband"
If you live in Canada and have a 4 wire dryer receptacle, Home Depot (Canada) sells a device that will do what you want. If you are in the USA, it is not compliant.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
01-02-2013, 06:11 PM
#4
RJ, do you know if that device has a breaker on it ? Or, are you plugging a 15 amp appliance straight into a 30 amp circuit ?
01-02-2013, 06:30 PM
#5
Most dryer receptacles in the U.S. provide both 120 (110) volts and 240 (220) volts because the dryer uses both.
You can make a power strip (portable subpanel) with a cord that plugs into a 120/240 volt dryer receptacle and that has some 120 volt receptacles protected by 15 amp or 20 amp breakers. This cannot be used on a 240 volt only dryer circuit; you may not use ground as a neutral for 120 volts.
You may not have 15 amp or 20 amp rated receptacles connected directly to a circuit that can supply more than 20 amps.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
01-02-2013, 06:38 PM
#6
Licensed Electrician
No you can't. A sub panel would need to be hardwired.
Location...Location...Location
01-02-2013, 06:45 PM
#7
I hadn't heard that. Does it have a 15a breaker in it? Why isn't it USA compliant?
I don't even have a 240v outlet, but am just curious.
01-02-2013, 06:52 PM
#8
A "Handy Husband"
I believe it has an inline (internal) fuse to limit it to 15 amps. I was just looking at the HD Canada web site but could not find the unit but I have seen it in the past.
The Following User Says Thank You to rjniles For This Useful Post:
01-02-2013, 09:12 PM
#9
Most North American dryers can be wired to run on 110V. However, as noted, there is no complaint way to do it. Further, it will take forever to dry.
01-03-2013, 03:43 PM
#10
A "Handy Husband"
Here is that adapter to convert a 4 wire receptacle to a 120 volt 15 amp receptacle.
Noticed it a range recep, converter not a dryer
Sold at Home Depot Canada. Not UL listed.
http://www.homedepot.ca/product/gas-...adaptor/905477
Has internal 15 amp fuse.
Not sure why it would not meet code in US but it would be a useful device.
01-03-2013, 04:51 PM
#11
$33 isn't cheap, but I expect an electrician would be several times that; nice device.
I have seen a device that does just the opposite. You plug it into two outlets on opposite legs and it makes 240v. I hope that is illegal everywhere.
01-03-2013, 04:57 PM
#12
Is it possible - YES ! but only if it is a 4 pin recepticule !
But it may not be code compliant !
You should not use ground as neutral.
Its basically risky if not done right.
which is why its NOT code compliant.
01-04-2013, 07:01 AM
#13
Master Electrician
It's a converter listed for gas range applications. I've never seen one before but generally we can only use devices for their intended purpose so plugging anything other than a gas range into it may be illegal as it states its for gas ranges only.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
01-04-2013, 08:41 AM
#14
The receptacle for a dryer is different than a receptacle for a range. Unless you can find an adapter from dryer to 120 that one pictured will not work.
That adapter is only available in Canada. I have been able to find it listed on any USA sites.
Do not PM with questions that can be asked in a forum. I will not respond.
#15
The other fact is that Range plugs and Dryer plugs are not the same pin out, due to the different current ratings.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
