Is There Any Typical Height For Kitchen Counter Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2009, 06:52 PM   #1
Is there any typical height for Kitchen Counter outlets
having a hard time deciding how high to go.
NHERal is offline   Reply With Quote
Old 03-22-2009, 07:06 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
A good little rule of thumb is 12". I go 12 to the bottom but some may go center or top.
wirenut1110 is offline   Reply With Quote
Old 03-22-2009, 07:10 PM   #3
Licensed Pro
I usually set them at 48" off the finished floor (to the top of the box).
Old 03-22-2009, 07:13 PM   #4
Rewards Points: 510
So I don't get yelled at, I meant 12" above the counter top
Old 03-22-2009, 07:24 PM   #5
Idiot Emeritus
Rewards Points: 1,492
I kinda figured that!
Since the standard kitchen countertop height is 36", 48" from the floor is about right.
Rob
micromind is offline   Reply With Quote
Old 03-22-2009, 11:44 PM   #6
Standards here are 36" cabinets plus 2" top plus 4" splash = 42 plus a couple inches for reveal = 44" minimum.
Upper cabinets start @ about 54"
220/221 is offline   Reply With Quote
Old 03-23-2009, 05:55 AM   #7
Or maybe centered between CT and upper cabinets(18" space), 14" above CT.
Old 03-23-2009, 07:40 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Me too.
Old 03-23-2009, 02:47 PM   #9
If I'm tiling I try to make sure they will not leave a small edge of tile on one side/top or bottom
Some people like them righ up under the cabinits so that they will not be as noticeable. I think code indicates they can not be higher then 18" above the counter top ?
Old 03-23-2009, 06:28 PM   #10
as seen on tv
Rewards Points: 150
individual counter spaces greater than 12in require receptacles
spacing so no point is less than 24in from recept
max is 20in above countertop
qbert is offline   Reply With Quote
Outlets on both sides of wall? and height question DIYGST Electrical 10 02-08-2009 06:11 PM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 11:53 AM
Laundry room counter height? kcrossley2 Carpentry 7 05-09-2008 03:10 AM
Increase counter height on bath remodel sharisavage Remodeling 4 01-22-2007 11:44 AM
Bathroom Outlets - How far above finished cabinet height? MikeinBurien Electrical 4 12-10-2005 11:11 AM
