Testing Two Prong 20 Amp 220 VAC Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2014, 03:23 PM   #1
Rewards Points: 45
Testing two prong 20 amp 220 VAC outlet
I have installed this little guy in my garage for a 20" planer...
http://www.lowes.com/pd_70708-334-18...3D2&facetInfo=
I used 10/2 wire and put the white and black wires just like they already were in the existing unused double pole breaker in my breaker box and the other end in wired to the outlet per the wiring diagram for the breaker. I have a digital multimeter I would like to check my work with, but I'm a little confused by the two positive wires thing. Would I check each of the + wires separately with the ground?... or would I check both positives at the same time?... if so does it matter which hole the + and - tester goes in? help would be appreciated.
giser3546 is offline   Reply With Quote
Old 06-15-2014, 03:30 PM   #2
Licensed electrician
Rewards Points: 1,794
You can check from hot to hot and from both hots to ground. With a two pole breaker there should be little need to test for voltage.
Old 06-15-2014, 03:35 PM   #3
Rewards Points: 45
Much appreciated, this would be my first attempt at 220 VAC and I have assured myself that every step I a hair away from letting out the magic white smoke.
Old 06-15-2014, 03:39 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
It should read 240 across the 2 flat blades and 120 from each flat blade to the ground pin.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
micromind (06-15-2014)
gas oven has 3 prong plug, outlet is 4 prong Lylebillie Electrical 9 06-21-2012 04:43 AM
odd outlet.... trying to change to a 3 prong gfi socrates Electrical 12 06-13-2012 03:08 AM
Cook Stove Outlet - 3 prong old range vs. 4-prong new range Patricia C. Bai Electrical 2 12-20-2011 02:21 PM
one outlet testing at 115 volts stanlam Electrical 13 10-04-2009 11:10 AM
220volt 3prong outlet swap to 4 prong rp1666 Electrical 4 08-20-2009 09:03 PM
