Testing Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 10:20 AM   #1
Testing switch
How do I go about testing a switch in my home without getting electrocuted? My blower motet for my fireplace is ran by a switch and the blower is not working.
Dooggins1 is offline   Reply With Quote
Old 11-07-2011, 04:55 PM   #2
joed's Avatar
Rewards Points: 12,362
Turn off breaker. Take switch out and connect two wires together. Turn on breaker. If motor runs switch is bad. If motor doesn't run then motor is bad or wring has loose connection.
You could use an ohm meter to test the switch after removing it.
Old 11-07-2011, 08:17 PM   #3
I will try that. I took the switch out today and noticed it didnt have a ground wire on it. Is that normal?
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
