Old 01-31-2010, 04:48 PM   #1
Testing Station
Hi,
I am trying to wire up a testing station. It will test 8 washing machines at once.
If I use a consumer unit with 4 separate mcb's (4 double sockets) which size mcb's do I need?
The washers are normal household 13 amp 240v washers.
Also, with this loading which size cable should I run to the consumer unit.
thanks
Fred
budget888 is offline   Reply With Quote
Old 01-31-2010, 07:32 PM   #2
Xtreme DIY'r
Testing Station
Originally Posted by budget888 View Post
Hi,
Since when is a 240v washer normal ?
I've never had one
Are these combo washer/dryers ?
Old 01-31-2010, 07:38 PM   #3
Testing Station
If you intended to say the washers are 13 amp 120 volt...
If you are testing, then to be scientific, I should think you would want the same electrical supply as in a home...
8 separate 20 amp breakers.
8 separate GFCI outlets.
1 washer to each GFCI.
12 gauge wiring to each. Separate wiring to each outlet. [No shared neutrals (no multi-wire branch circuits)].
Billy_Bob is offline   Reply With Quote
Old 01-31-2010, 07:43 PM   #4
Testing Station
I've never had one
It is when the OP is from Wales.
jerryh3 is offline   Reply With Quote
Old 01-31-2010, 07:46 PM   #5
Xtreme DIY'r
Testing Station
Yup, UK according to the IP...I was thinking Swansea MA
So (8) 20a 240v circuits
Old 01-31-2010, 08:20 PM   #6
Testing Station
Re: Wales... GFCI = RCD (Or whatever would be in a typical home).
RCD...
http://en.wikipedia.org/wiki/Residual-current_device
Old 01-31-2010, 08:41 PM   #7
Unhappy
Testing Station
I've never had one
Still, in the Good Ol' USA and in Canada (to the best of my knowledge), a washer runs on 120v. The dryer (if heated by electric heating elements, is 240v.) to the OP!
spark plug is offline   Reply With Quote
Backflow device testing - possible scam? ScottR Plumbing 9 06-14-2009 11:55 AM
Testing circuit with GFCI protection Hodag Electrical 4 09-15-2008 11:43 PM
Testing DC Rze Electrical 3 09-15-2007 10:02 AM
Testing for a gas leak haynesk Plumbing 2 07-27-2007 08:11 PM
Testing Formss Deano710Sparkey Electrical 2 04-13-2007 02:33 AM
