Testing Start And Run Capacitors - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2013, 07:25 AM   #1
jburd964's Avatar
Rewards Points: 166
testing start and run capacitors
How can I check if 220 volt start and run capacitors are functioning?
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 06-07-2013, 07:28 AM   #2
Rewards Points: 3,130
You really can't without special test equipment that is not cheap. You'd be better off to just replace them.
Old 06-07-2013, 07:38 AM   #3
jburd964's Avatar
Rewards Points: 166
I have fluke meter and have done it before just can't remember how.
Old 06-07-2013, 08:39 AM   #4
JW
mm11's Avatar
Rewards Points: 622
What kind of a Fluke? Can it test for capacitance?
mm11 is offline   Reply With Quote
Old 06-07-2013, 09:18 AM   #5
I'd be very surprised if it could.
Old 06-07-2013, 10:54 AM   #6
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
http://www.teknetelectronics.com/Pics/WEBFLUKE110.jpg
I have one of these Fluke 110 in my collection that tests capacitance. Have it for that reason. Very inexpensive.
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
jbfan (06-07-2013)
Old 06-07-2013, 12:26 PM   #7
jburd964's Avatar
Rewards Points: 166
Surprisingly I actually own 2 pictures attached.
Old 06-07-2013, 02:44 PM   #8
jbfan's Avatar
Rewards Points: 552
What you have will not check capacitance.
You can test the caps in the ohms position.
Touch the leads to each terminal, then swap the leads.
You may see the cap charge and discharge, but this is not a real test to see if they are any good.
jbfan is online now   Reply With Quote
Old 06-07-2013, 04:56 PM   #9
dmxtothemax's Avatar
Rewards Points: 5,500
To properly test capacitors you need to test three things,
1 - capacitance.
2 - esr (equivelent series resistance).
3 - leakage.
1 - If you are lucky you might have or get a capacitance meter.
2 - esr meters are available, but mostly only electronic repairers
will have these types of testers.
3- A MEGGAR style type tester is used by electricains.
dmxtothemax is offline   Reply With Quote
Old 06-07-2013, 06:20 PM   #10
jburd964's Avatar
Rewards Points: 166
Think I'll just bring them to shop for testing
Old 06-07-2013, 06:26 PM   #11
Rewards Points: 1,192
Capacitors will check good or bad using ohms scale but they might not be in the + or - % the capacitor needs to be in tolerence for the motor.I have Flukes with cap setting and a Kappy tester.
bobelectric is offline   Reply With Quote
Tags
220 volt , capacitors , test
