Testing Home Telephone Line - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2009, 06:55 AM   #1
Folks,
I want to test my home telephone wiring. How do I do that? I have VOIP service and not a traditional phone line. Even though I won't be using any of the phone jacks (home telephone line), I just want to check and make sure everything is working as it should.
Can someone suggest a simple way to test the telephone wiring?
Kirridam
kirridam is offline   Reply With Quote
Old 08-01-2009, 10:35 AM   #2
http://www.usahardware.com/inet/shop...c/tt6200_l.htm
jerryh3 is offline   Reply With Quote
Old 08-01-2009, 02:58 PM   #3
Rewards Points: 174
jerry3, Good link. Never saw one of those before.
VOIP uses the same phone cables as any other phone. There is no difference. It's like DSL for your computer. Same wire just a different frequency (I Think) on it for the DSL connection. DSL and phone both use the same to wires in the jacket.
The esiest way to check the phone jacks yourself is to plug a phone into it and see if you get a dial tone. Your phone company also has a meter they use to check for signal strength. If you are covered inside the house by the phone co. they may check each jack for you.
Old 08-02-2009, 08:12 AM   #4
Originally Posted by jerryh3 View Post
JerryH,
Can I use that equipment to test the phone lines even if it is not connected to a phone company? I'm not using any of my phone jacks. I have VOIP where a wire is connected from the VOIP adapter to a panasonic base with 3 wireless phones. Will that equipment be able to detect if the phone lines in my house are wired properly?
thanks
kirridam
Old 08-02-2009, 07:39 PM   #5
Yes. Plug the phone cord from the phone adapter into any of the wall plates in your house. Then, go to each plate and check it with the tester.
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
Replacing damaged BX line in kitchen wall fishnyc22 Electrical 5 02-17-2009 12:40 PM
Telephone line static without external filters installed Unregistered Electrical 5 11-21-2004 12:38 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
