Testing GFCI Turns Off Another Outlet. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 10:15 PM   #1
Rewards Points: 664
testing GFCI turns off another outlet.
I have a GFCI in my bathroom and when I press “test” the actual GFCI does not turn of like it should. However, an out let in the bedroom on the other side of the wall does shut off. When I press “reset” the GFCI stays the same, and the outlet in the bedroom turns back on. What is going on?
crescere is offline   Reply With Quote
Old 08-23-2012, 10:21 PM   #2
Rewards Points: 798
It could be they switched line and load on the GFCI. Newer GFCI's don't allow this but maybe you have an older one.
curiousB is online now   Reply With Quote
The Following User Says Thank You to curiousB For This Useful Post:
mpoulton (08-23-2012)
Old 08-23-2012, 10:22 PM   #3
kevinp22's Avatar
probabaly the wires on the back of the gfci are backwards.
Line (power in) wires on Load (power out to bedroom) terminals
+ Load wires on Line terminals
= load still protected, but actual gfci receptacle not protected.
reverse where the wires go into the back of the gfci, or if you dont want that bedroom receptacle gfci protected, move the wires from the load terminal to the line terminals and leave the existing wires on the line terminals in place
kevinp22 is offline   Reply With Quote
Newly installed GFCI outlet trips when ceiling fan/overhead light is turned on vash1012 Electrical 8 07-15-2012 06:47 PM
Circuits in Garage and GFCI tedallen Electrical 19 05-24-2012 07:03 PM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 05:38 PM
How to include a GFCI outlet with multiple loads Gwennr Electrical 5 10-13-2010 10:31 AM
GFCI from basement laundry to outdoor outlet TPS Electrical 11 01-15-2009 12:17 AM
