Testing Exposed External Coax For Signal - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2013, 02:22 PM   #1
Rewards Points: 12
Question
Testing exposed external coax for signal
My question:
Is there is a way to test an exposed external coax for signal without an rf current clamp? By exposed, I just mean not buried - the cable itself is not damaged.
Here's why:
I moved into a house about 2 years ago that was used, abused, neglected, and trashed by its previous owner. The electrical wiring is good (thanks to a kitchen reno and AWESOME electrician who fixed several serious issues in addition to what he was contracted for), but the coax is an absolute mess. There are multiple lines running from the house to the cable box, but only ONE of them is live and all are buried. There are at least two dead cable connections (whether jacks or cables coming out of the wall) in every room in the house. The coax feeding them has been chewed through by mice or inexplicably cut, and the previous owner ran new coax to either a new box and jack or through a new hole in the wall (but took the time to use clamps to secure it to the studs in the wall ). The exterior line that I am curious about may feed the entire bottom level and I don't want to cut it if it does. It comes out of the ground near the foundation (<1" between wall and cable) and enters the house through the exterior siding and wall just above the sill plate. I'm not sure where it is (or was) connected to on the interior side of the wall. The room on the other side of the wall has four dead jacks and two live ones, none of them on the wall the exterior cable goes into.
Any suggestions for a way to test that line for signal is much appreciated. (And just cutting it and seeing what happens has already been suggested by my wife).
SrsBidness28 is offline   Reply With Quote
Old 09-24-2013, 03:14 PM   #2
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by SrsBidness28 View Post
My question:
Here's why:
I use this ...LOL
http://www.flukenetworks.com/datacom...Cable-Verifier
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 09-24-2013, 03:40 PM   #3
Rewards Points: 12
Thanks for the quick reply and the laugh. If I had $500 to spend on a cable verifier, I would already have one.
Let me clarify: Is there something at a DIYer's level that can do the job?
Old 09-24-2013, 03:42 PM   #4
Rewards Points: 516
hook ur tv up and then start disconnection down where ever when the TV goes off you got the right cable ...
Old 09-24-2013, 04:02 PM   #5
Rewards Points: 12
I am not even sure if the coax on the exterior of the wall is carrying a signal - that's what I am trying to determine. I found two dead cables in the ground this summer (and not because I cut them). Both of them run right near where this cable is. I had the cable company check them when I found them, and made sure I didn't accidentally cut a neighbor's cable. One terminated on one of the previously cut lines where the current live one comes into the house (there are three cut lines). The tech couldn't find where the other one terminated, though and after telling him about the mess that the coax was inside, he just tested the ends where the live lines come in and determined it wasn't one of them. Cable company is going to charge to come out again, so I want to try to find a cheaper option.
Old 09-24-2013, 06:07 PM   #6
Rewards Points: 6,652
Here, the cheapest continuity tester for Coax that you can get http://www.amazon.com/Steren-203-550...ax+tone+tester
Old 09-24-2013, 10:25 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,354
On a DIY level, all you can do is,
phyisically follow the main feed coax,
find it's first joint and tap into it there !
you will need to position a tv near by,
hook it up, and see what,s there !
Most instalers use specialist equipment,
which can be expensive !
dmxtothemax is offline   Reply With Quote
Whole House CAT6 & COAX wiring. ATLChris Electrical 4 05-21-2013 02:40 PM
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Backflow device testing - possible scam? ScottR Plumbing 9 06-14-2009 10:55 AM
