Old 09-15-2007, 12:13 AM   #1
Rze
Average Joe
Testing DC
While I'm fairly proficient with AC, I've not had much experience with DC. I would have thought that testing a DC circuit was pretty much the same (one lead on Ground or Nuetral and one on the line in.) I tried to test (using a DC tester) a circuit for trailer lights on my car. When I plug it in, it works, so I know the circuit is good, however when I test it at the car, I don't get a result. Is there a trick to testing DC?
Rze is offline   Reply With Quote
Old 09-15-2007, 12:54 AM   #2
Cabinet Installer
Dansbell's Avatar
Testing DC
Can you explain your results a little more? How do you know the circuit is good? are you measuring Ohms (continuity)? I am not sure I understand how you are preforming the test? Testing DC voltage is really straight forward. Make sure your meter is set to the proper DC voltage (12v for your car) and place the positive (red) lead on the positive wire and the ground (black) lead on your ground.
Daniel S. Bell
Belbuilt, LLC
Cabinet Installation Medford, Oregon
Dansbell is offline   Reply With Quote
Old 09-15-2007, 09:30 AM   #3
Rze
Average Joe
Testing DC
Circuit is good since I plug in the trailer and the lights work...directionsls, lights, Hazrds and Brake. I did as you outlined as that makes the only sense. I must have a bad meter.
Old 09-15-2007, 10:02 AM   #4
I have gas!
Clutchcargo's Avatar
Testing DC
The fuse in the multitester is probably blown.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Testing for a gas leak haynesk Plumbing 2 07-27-2007 08:11 PM
Testing Formss Deano710Sparkey Electrical 2 04-13-2007 02:33 AM
Gas Line pressure testing standard(s) rolson6432 Plumbing 1 09-09-2006 03:33 PM
