Testing Circuits - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 01:59 PM   #1
Testing circuits
I was installing an outlet box last night. Naturally, the circuit was de-energized while I worked on it. Before energizing the circuit, I wanted to check out my work with a multimeter. My thinking was that I should not get continuity between the hot and neutral. However, when I plugged the leads into the respective sockets, there was continuity. This didn't seem right, yet other plugs in the house tested out the same way.
It seems like I've run into this before years ago, without understanding exactly why this is the case.
I decided that everything was wired properly and flipped the breaker. Upon testing, the outlet had normal voltage, as one would expect.
What is it that I don't understand about AC electricity that would indicate continuity between the hot and neutral wires in a circuit that has been de-energized?
donkeyhotay is offline   Reply With Quote
Old 01-14-2008, 02:48 PM   #2
Licensed Pro
You are measuring the resistance across something on that circuit that is in the on position. Maybe a lamp or transformer?
Old 01-14-2008, 02:57 PM   #3
Follow the path grasshoppa.
If a light (for example) is switched on anywhere on that circuit, that is where your continuity comes from.
220/221 is offline   Reply With Quote
Old 01-14-2008, 03:02 PM   #4
DOH! Of course! That would explain it. Thanks.
Old 01-14-2008, 06:22 PM   #5
Electrician philosopher
220 is dead on here. It is all about the circuit. It is a big Merry Circle we live in called a circuit. OHMS are always read thru a resistive path...
Andy in ATL is offline   Reply With Quote
Testing DC Rze Electrical 3 09-15-2007 09:02 AM
Testing for a gas leak haynesk Plumbing 2 07-27-2007 07:11 PM
Power circuits under leaky bathtub? Beren Electrical 1 07-23-2007 09:02 AM
Testing Formss Deano710Sparkey Electrical 2 04-13-2007 01:33 AM
One neutral for two circuits?? TronCarter Electrical 13 01-14-2007 08:21 AM
