testing a ballast
hello,
how do u test a ballast in a flouresent light fixture? should there be a specific voltage where the tubes plug in? it has two "23, 20 watt tubes. the tubes only light at the ends. i could replace the tubes and see if that works, but the tubes are about $8.00 a piece, so i would like to make sure its not the ballast first. if it is, ill just buy a new fixture. bob:eek: |
I put new tubes in. If they don't light up then I change the ballast.
The same as joed.
Trying to test a ballast is a waste of time. |
hello,
yeah. ill probally just buy another complete fixture. a 23" flourescent fixture is probablly only about 25 bucks...bob |
| All times are GMT -4. The time now is 09:49 AM. |
