Old 09-29-2012, 08:31 PM   #1
kbc
testing amperage
i want to test my amperage on a new 200 amp service i got installed, if i use a clamp meter should each leg have 100 amps, if there is a difference between them should the difference be on the neutral
kbc is offline   Reply With Quote
Old 09-29-2012, 08:40 PM   #2
Master Electrician
testing amperage
Each leg will show whatever the load on that leg is up to 200 amps or so, per leg.
brric is offline   Reply With Quote
Old 09-29-2012, 08:42 PM   #3
Electrical Contractor
testing amperage
If you were in fact using the full 200 amps, you would read 200 amps on each leg.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 09-29-2012, 08:45 PM   #4
kbc
testing amperage
how do u know if u truly have 200 amps, a friend of mine thats a electrician said something about the ground in the house that i possibly may not be getting a full 200 amps
Old 09-29-2012, 08:47 PM   #5
Master Electrician
testing amperage
Huh?????????????
The Following 4 Users Say Thank You to brric For This Useful Post:
Code05 (09-30-2012), jbfan (09-29-2012), jrclen (09-29-2012), mpoulton (09-29-2012)
Old 09-29-2012, 08:51 PM   #6
kbc
testing amperage
thats exactly where im at right now , saying huh?????
laughing
Old 09-29-2012, 08:53 PM   #7
testing amperage
Did you have this install inspected?
Was this a new install or an upgrade?
Old 09-29-2012, 08:55 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
testing amperage
..., a friend of mine thats a electrician said something about the ground in the house that i possibly may not be getting a full 200 amps
This friend heard something and had NO idea what they were talking about, then told you what he thought they said.
The way you tell if you have a 200A service is by the size of the service cable, meter pan and main panel (or disconnect).
If all is correct, just look at the number on the main breaker. That is what size service you have.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
AltaSparky (09-29-2012), frenchelectrican (09-30-2012), jrclen (09-29-2012)
Old 09-29-2012, 08:56 PM   #9
kbc
testing amperage
upgrade i originally had 100 amps but i adding an addition on my house so i upgraded
Old 09-29-2012, 10:27 PM   #10
JOATMON
ddawg16's Avatar
testing amperage
Go look at the main circuit breaker in your panel It should be a double poll and say 200 on it. If this was properly done and inspected, then I'm sure your ok.
You need to talk to you 'electrician' and get a better explination from him on what he means.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 09-29-2012, 10:30 PM   #11
Licensed electrician
testing amperage
The clamp meter would read would only read what was actually being used, not what the system is capable of supplying.
joecaption (09-30-2012)
Old 09-30-2012, 12:55 PM   #12
biggles's Avatar
testing amperage
keep in mind that 200A panel is protection for the service from your panel to the pole and the wire sized to handle it from the upgrade
Old 09-30-2012, 01:11 PM   #13
Master Electrician
testing amperage
The service from the panel to the pole is only protected by the POCO primary fuses, not by the panel breaker and/or disconnect.
Old 09-30-2012, 02:01 PM   #14
Send a message via AIM to theatretch85
testing amperage
When I did my new panel install (replaced an FPE panel) I sized the wire from the meter to the panel for 200 amp service, but the inspector made me change out the main breaker from 200 to 150 (the original main breaker of the FPE panel). I still have the 200 amp main and I already know I don't have to re-buy the service wire from the meter to the main breaker if I ever want to go to 200 (I doubt I will ever need it).
theatretch85 is online now   Reply With Quote
Gas Pressure Testing With Manometer a_lost_shadow Plumbing 4 07-01-2012 05:36 PM
Dual Pole Breaker Amperage Question jcwilshire Electrical 2 11-22-2010 01:45 PM
Resi breakers, testing of Yoyizit Electrical 10 07-14-2010 08:49 PM
main circuit breaker amperage kupalino Electrical 13 12-23-2009 09:32 PM
Backflow device testing - possible scam? ScottR Plumbing 9 06-14-2009 11:55 AM
