Old 03-23-2011, 06:41 PM   #1
Test Breaker
I have Zinsco type breakers. One in the box has no lever and only the word "test", looks like a button to press. It does have a circular wire on one side like a GCFI. I have not tried it since moving in in 1978. What is the purpose and is it needed? With limited space, I sure could use another breaker.
Ken
kennybug is offline   Reply With Quote
Old 03-23-2011, 07:52 PM   #2
Just call me Andrew
Test Breaker
What is on this circuit? It is probably a GFCI.
Andrew
secutanudu is offline   Reply With Quote
Old 03-23-2011, 09:33 PM   #3
Electrical Contractor
kbsparky's Avatar
Test Breaker
Sounds like a broken GFI breaker. Too bad the handle is broke. Fodder for the landfill ....
-KB
Old 03-24-2011, 08:51 PM   #4
Test Breaker
Took the front of the panel off and followed the wires. It is a GFCI but part one (or part two) of a breaker. Don't know why it is different than the rest. But thanks for the input.
What would be the benefit of having just one GCFI breaker? It does go to the outside outlets. Is it mandatory to have a GFCI breaker if the outside outlets are GCFI? Or is that over kill?
Old 03-24-2011, 09:34 PM   #5
kbsparky's Avatar
Test Breaker
Yes, it has been mandatory for almost 40 years to have GFCI protection for outside outlets. This requirement was first found in the 1971 edition of the NEC.
In them days, it was common to have only one GFCI device -- oftentimes a breaker in the main panel -- which fed all the required outlets. They used a single GFCI device due to the high costs associated with them, since wire was cheap.
Nowadays, wire is way more expensive, and the GFCI devices are cheap. Go figure.
-KB
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 11:13 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 12:18 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
