Terminating Two Lines In One Box - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2007, 11:35 PM   #1
Question
Terminating two lines in one box
I just bought a place from 1957 and am doing a bit of rewiring. Currently, two bedrooms and a bathroom as well as the fridge are on one circuit. I've rewired the bathroom so it shares a circuit with the kitchen, and the bedrooms (as well as the fridge) are on a circuit they share. I've got limited options because the basement is finished off, though when I come to redo that in a couple of years I plan to upgrade the service to the house at the same time. So, I'm more worried about safety aspects to this question.
My question is this - I have a wire being fed from a finished section to the bathroom that is live. I don't need it anymore, because I ran all new wiring for the bathroom (as we've pulled down all the drywall in it for renos). Can I terminate the original feed in the same box I've used for my fan/light switch? My plan would be to single marrette the neutral and hot, and ground the line to the box.
Here's a quick diagram, as best is possible:
Code:
----live 110 (new)----------->|------- |
            <-----to fan------|-^  ^   |
          <-----to light------|----|   |
----live 110 (old)----------->| (term) |
phantoz is offline   Reply With Quote
Old 09-25-2007, 11:26 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Yes. Put wire nuts on the ends of the wire, make sure they are tight, and put in the back of the box.
jbfan is online now   Reply With Quote
Old 09-25-2007, 01:05 PM   #3
Rewards Points: 58
When do you hope to correct the installation mistakes you mentioned.
Fridge....seperate circuit!
Bath and Kitchen on same circuit?
Old 09-25-2007, 03:05 PM   #4
jbfan: thanks!
j.v.: looks like at least a year before we can gut the kitchen. The kitchen will see a host of changes, and at that time I'll stick the bathroom on its own circuit. Fridge will definatly be by itself!
thanks again...
Attaching water lines to floor joists handyflyer Plumbing 8 04-30-2007 11:43 AM
new water lines JahDoos Plumbing 11 02-22-2007 10:43 PM
air in water lines chattiechick Plumbing 2 11-01-2006 01:36 PM
Old Water Supply Lines in Kitchen and Bath Faucets skittlzski Plumbing 2 08-08-2006 10:13 AM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
