Terminating Active Cable In Renovation - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 09:17 PM   #1
Rewards Points: 1,062
Question
terminating active cable in renovation
i was wondering what the proper way to terminate an active cable during renovations is. e.g. when you renovate half the house and the cable starts at a box in the non-renovated part so you don't have an easy way of knowing which box it is and it's coming out in the renovated part but you no longer need it to go further. is it acceptable to just terminate it in a junction box or can you even just strip the cable and put connectors over each wire?
Old 05-16-2011, 09:29 PM   #2
Licensed electrician
Rewards Points: 1,010
I am assuming you are refering to an electrical cable, you can either blank it off in a permanently accessible junction box with a blank cover, or you can remove both ends from the boxes and abandon the cable.
amakarevic (05-16-2011)
Old 05-16-2011, 09:42 PM   #3
of course the latter is preferable but is not an option because i don't know where it starts (and don't feel like testing).
Old 05-16-2011, 10:20 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
You can't leave an unterminated cable. It will need to be in an accessible junction box. Is this cable live? If yes, I would just make a receptacle out of it if the wall is open and you can move it to a decent spot.
The Following User Says Thank You to Red Squirrel For This Useful Post:
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Effects of electrician tape on cable richard7994 Electrical 4 08-11-2010 09:39 AM
Terminating an unused cable acerunner Electrical 6 03-24-2010 06:32 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
