#1 |
Terminate stranded THHN/THWN on SQ D breaker
Is it allowed to terminate stranded THHN/Thwn under the clamp of a Square D circuit breaker? If not, how should the strands be dressed prior to termination?
Thank you, Mike |
#2 |
yes it is listed for solid and stranded
| The Following User Says Thank You to carmusic For This Useful Post: | Mike2401 (10-26-2011) |
#3 |
Average Joe/ex-Navy IC3
Mike, strip about two inches of insulation, but as you are removing the section, twist it clockwise ever so, about two full turns. Then cut the end after removing the cut section of outer sheath, leaving about 1/4" of bare wire.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| The Following User Says Thank You to gregzoll For This Useful Post: | Mike2401 (10-26-2011) |
#4 |
Licensed electrician
Just strip the proper amount and insert in the clamp and tighten.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
| The Following User Says Thank You to Jim Port For This Useful Post: | Code05 (10-26-2011) |
| Display Modes | |
| AFCI Breaker Keeps Tripping | Muinchja | Electrical | 30 | 08-25-2011 05:54 PM |
| Faulty Breaker? | bpm | Electrical | 4 | 08-09-2011 07:17 AM |
| Stranded wire in breaker? | gma2rjc | Electrical | 3 | 09-25-2010 01:00 PM |
| Wire size and Breaker size for remodel ?? | Skydmark1 | Electrical | 12 | 12-15-2007 06:00 PM |
| 20 Amp Breaker tripping with GFCI | panhandlion | Electrical | 7 | 12-12-2007 09:59 PM |
