Temporary Power Pole Code - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2010, 07:10 PM   #1
Rewards Points: 274
temporary power pole code
I have looked at several of these around here, and they don't have GFI outlets or breakers, (they are in waterproof boxes of course) and have all passed inspection. Is GFI not needed, just going by NEC ? Thanks,
ugabulldog is offline   Reply With Quote
Old 05-22-2010, 07:12 PM   #2
Where is "around here" ?
Old 05-22-2010, 07:24 PM   #3
Rewards Points: 274
SC but I will be building in GA
Old 05-22-2010, 07:27 PM   #4
Master Electrician
Rewards Points: 3,750
NEC does not cover these installations regarding GFCI's. OSHA requires GFCI protection on construction sites.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Scuba_Dave (05-22-2010)
Old 05-22-2010, 08:31 PM   #5
Rewards Points: 274
Well that explains it.....I saw a temp. pole on a commercial site that had GFI, and that's why I started second guessing.
Old 05-22-2010, 10:18 PM   #6
Registered User
Rewards Points: 5,216
590.6A: Page #6- temporary wiring- http://books.google.com/books?id=eLo...590.6A&f=false
WOW! the liability......
Be safe, Gary
Old 05-23-2010, 12:14 PM   #7
Rewards Points: 274
Be safe, Gary
So, this says I do need gfi..?? Now I'm confused...
Old 05-23-2010, 01:08 PM   #8
Registered User
Yes, if your State/City/County/Township is under the NEC. Check with your local Building Department......
Be safe, Gary
Could I move my Meter & Power Drop to the Side of my house? jamiedolan Electrical 9 07-28-2010 06:16 PM
Power to new pole barn/garage. Camonica Electrical 9 04-02-2010 12:04 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 11:06 AM
