Temporary Power Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 10:07 AM   #1
I=E/R
a7ecorsair's Avatar
I am having a garage/shop built on my back lot. The PoCo will place a meter pan with a disconnect switch (not an OCPD) on a utility pole that is already in place and about 40 feet from the garage.
What will I need for temporary construction power? I know I need GFI receptacles and OCPD but what about the ground? Will I have to drive a rod?
a7ecorsair is offline   Reply With Quote
Old 04-21-2012, 10:46 AM   #2
Master Electrician
Rewards Points: 3,698
We are required to use ground rods on the temps we install.
brric is offline   Reply With Quote
Old 04-21-2012, 11:32 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Even though temporary, you will need a main breaker load center and ground rods.
Some areas may allow a main lug load center if less than 7 breaker handles (throws).
Ask your AHJ.
Coastal South Carolina
Old 04-21-2012, 11:56 AM   #4
Code05's Avatar
Rewards Points: 1,104
You will actually probably need 2 rods, testing is not worth the cost. Nothing in 590 relieves you from 250.
Code05 is offline   Reply With Quote
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
new sub panel BlueBSH Electrical 11 01-22-2012 09:28 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 01:43 AM
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 06:39 AM
power to a sub panel BigHill Electrical 7 08-03-2010 02:36 PM
