Temporary Power... - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2007, 01:39 AM   #1
MLO
Temporary power...
Demo'ing a home and rebuilding on the existing foundation. The lot has a new fully functional 18x24 shop with a grounded 150amp panel powered from the homes panel via a 100 amp breaker. The buried sheathed cable between the two (50ft) is a 1/0 I believe.
Could the shops panel be hooked up to a temporary power box during construction?
MLO is offline   Reply With Quote
Old 02-17-2007, 08:06 AM   #2
Yes you can
jwhite is offline   Reply With Quote
Old 02-17-2007, 10:18 PM   #3
MLO
Does that mean I will need a temporary panel with a meter, so the shop can be hardwired to it?
Old 02-18-2007, 06:55 AM   #4
If the owner of the house does not mind paying the electric bill, you do not need a meter at the new temp panel. Just put an outdoor panel on a pole. put in a ground rod and treat it as a seperate building.
Old 02-18-2007, 11:29 AM   #5
MLO
I am the home owner. I was under the impression a meter had to be installed to measure the power usage for billing. So it sounds like they will bill a flat fee?
Old 02-18-2007, 03:18 PM   #6
jproffer's Avatar
Rewards Points: 702
Doesn't the main house have a meter on it now? Isn't that what you're talking about...taking power from the main house and making a sub-panel (of sorts) at the shop? The POCO doesn't care where the power is going as long as someone is paying for it.
EDIT: Reread your original post...the shop gets power from the house (which is being taken down). Gotcha.
Take the meter off of the house and put it on a pole next to the building site. No need to run all the way back from the shop, just put temp service on that pole.
jproffer is offline   Reply With Quote
Old 02-18-2007, 08:57 PM   #7
MLO
Thanks jproffer...Yes, the shops panel is being powered by the homes panel/meter. The home is being demo'd, so I was wondering how to keep the shop powered during the new build.
What should I use for a pole? I figure I can do that before having an electrician do the hook-up.
Old 02-18-2007, 09:34 PM   #8
jproffer's Avatar
Rewards Points: 702
Although they may not be as strict with a temp service as they are with permanent service, the POCO will probably have specs you have to follow to have your temp service re-connected. <--on the record..
I would think a 4x4 buried 2 or 3 feet would be enough. <--off the record..
Speaking of re-connected, I don't think it's been mentioned, but I assume you knew it anyway but moving the meter from house to pole is not a "hot" job. Have the service drop cut before touching anything.
Old 02-19-2007, 12:43 AM   #9
MLO
Thanks, I will not be touching anything "hot". I have a scheduled appt. with an electrician before I go any farther.
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 11:58 PM
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 08:12 PM
Running a generator for power outages tropic home Electrical 5 12-04-2006 09:22 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
