Temporary Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2011, 09:56 AM   #1
For my new house construction I would like to have an outside temporary breaker box. The house will be feed by a 200 amp service with 4/0 underground cable. 200 amp outside breaker boxes are expensive. I only need a 50-100 amp breaker box during construction; however, I cannot attach 4/0 cable to these smaller breaker boxes, they wont handle cable that big. Is there anyway to setup a smaller breaker box with this size cable?
i_need_help is offline   Reply With Quote
Old 02-14-2011, 10:21 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
You can get a small 200A outside panel pretty cheap. You could even leave it mounted on the outside of your house. (the panel/panels in the house will be sub panels) If you do that will be your bonding point.
*I think the same box that you use on the (pole) temp service should be able to go onto the house for permanent service.
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-14-2011, 10:21 AM   #3
Rewards Points: 160
The way we do it, is to build a temporary pole with panel and disconnect. The power company will connect you up until the house is ready to be connected. Call the power company and ask them about the temporary pole.
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
GFCI breaker trips randomly BimmerRacer Electrical 40 09-21-2009 02:11 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
