Temp Power Pole ?? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2007, 09:08 PM   #1
Rewards Points: 274
temp power pole ??
I am obviously not an electrician so I will explain the best I can: I am building a house with a temp power pole. It only has room for 4 breakers. 2 are taken up by a 100 amp main breaker, the other 2 each have a 20 amp. My well pump requires a double pole 20, so I have to take out both single 20's to install. My question is: If I have the double pole 20 in to run the pump, is it ok to run regular power tools of this also? Thanks
ugabulldog is offline   Reply With Quote
Old 11-08-2007, 09:22 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 258
Can't believe I'm helping a dawg fan-GO JACKETS!
Now that we have that out of the way, the answer is no.
Your pump requires 240 volt nand the can not run your tools from this.
Is there a reason you need the pump to run before the house is completed?
jbfan is online now   Reply With Quote
Old 11-08-2007, 09:33 PM   #3
Rewards Points: 274
My tile sub needs water for his saw, mortar, and grout. I had to fill up the plumping lines for rough in inspection so I have already done the breaker switcheroo once. My tile guy said to leave him the breaker and he would swap out. I am curious, why can't you run power tools off this set up? btw... I cheer for the jackets as long as they aren't playing the dawgs. thanks again.
Old 11-08-2007, 10:42 PM   #4
Union Electrician
goose134's Avatar
The reason you can''t run power tools or any other 120volt appliances is because the circuit is 240 volts. Sure each leg is 120 volts, but you can't double tap the breaker in order to get the 120 volts you need.
goose134 is offline   Reply With Quote
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Temp Power 240v outside Mike S Electrical 3 01-15-2007 05:52 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
2 pole breaker Unregistered Electrical 3 09-11-2004 12:15 PM
