Temp Power 240v Outside - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2007, 01:11 PM   #1
Temp Power 240v outside
I'm in the process of building a house and right now. I'm doing all the electrical work myself. I'm hooking up the temp power unit. I allready have a few 20a/120v gfi circuits hooked up and they are requiring a 240v circuit. For compressors and equipment. I have not been able to find any out side GFI outlets that support 240v. A 20a/240v circuit would be sufficent. If any one know's where I can find one or if there is another way go about it I would appreciate it.
Thank for the help. Mike
Mike S is offline   Reply With Quote
Old 01-15-2007, 03:04 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
GFI protection is not required for 240v applications. Even temporary.
If you (or they) insist on GFI protection you'll need to use a two-pole GFI breaker and a standard 250v receptacle.
Old 01-15-2007, 04:02 PM   #3
Even if it's outside it doesn't require GFI?
The only receptacle I have found the is not a dryer plug has one strait and one sideways prong, plus ground. Is this the one you are refering to as standard?
Old 01-15-2007, 04:52 PM   #4
Nope. 240v applications DO NOT require GFI protection.
Seriously?
No, by standard I meant non-GFI. There are about 200 different receptacle configurations. Which one do you need?
Kenmore Refrig. Temp. ? kourso Appliances 1 07-09-2007 11:37 AM
Wiring 240v pump to generator - URGENT Benchr Electrical 4 12-19-2006 05:50 PM
Debugging Hot Water Heating System when on Standby Power hwitten Electrical 4 12-15-2006 08:47 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
