Temp Hot Tub Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 09:24 PM   #1
Send a message via MSN to reality
Temp hot tub wiring
Hey all just a quick question I just got a hot tub the family I got it from stated everything was working but befor I wire it pemmanatly I was wondering if I could unhook my a/c unit and temp wire it to that breaker. No one will use it while it is hooked up that way as all I want to do is check to ensure everything is working. I bought the wire I will be using for the permanent wireing but not the gfci or the new sub box or even the 50 amp breaker for inside. I do not want to spend all time or money just to find out it doesn't work. Thanks in advance for any help. the a/c unit is on its own 50 amp 220 the hot tub also requires a 50 amp 220.
reality is offline   Reply With Quote
Old 10-06-2012, 06:17 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm guessing that your "new" hot tub requires a neutral (120/240V) and your AC usually won't have one available.
Old 10-06-2012, 06:25 AM   #3
Yes the spa requires a neutral 2 hot and a ground.
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 10:00 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
