Telephone Wiring-twisted Pair? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 01:10 AM   #1
Telephone wiring-twisted pair?
Is it really necessary? I see it done in a lot of new installs, yet the traditional flat cable works just fine. I'm thinking of clearing some telephone wiring messes in my house. What the installers did is enough to make you cry.
rgsgww is offline   Reply With Quote
Old 11-30-2008, 03:48 AM   #2
Rewards Points: 2,350
If all you are doing is standard voice, then the non-twisted stuff is usually OK. It's when higher frequencies are involved, such as data transmission, that the twisted stuff becomes useful.
Old 11-30-2008, 01:42 PM   #3
DIYer
I ran my telephone on CAT3 and 4. :P
Maybe you should look around for CAT3 scraps that were abandoned wiring that was removed... you could probably get those nearly free on auction sites. I pulled mine out of the drop ceiling of my employer.
Gigs is offline   Reply With Quote
Old 11-30-2008, 02:13 PM   #4
This house has a mix of cat 3 and old round cable from 1960 in pvc or fabric insulation.
There are some telephone wire spaghetti messes....
Old 11-30-2008, 02:37 PM   #5
Flat wire at certain frequencies effectively becomes a short circuit.
For plain old phone use, its not a problem. However, DSL is now used extensively, and probably won't work very well on parallel wire.
When wiring for category 5. the twists must be maintained right up to the terminal and if jumpers are used, the twists must be maintained for these as well.
Twisted telephone wire is not really expensive, so there's little advantage in cutting corners.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 02:06 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
