-   -   Telephone wiring-twisted pair? (http://www.diychatroom.com/f18/telephone-wiring-twisted-pair-32855/)
rgsgww 11-30-2008 02:10 AM
Is it really necessary? I see it done in a lot of new installs, yet the traditional flat cable works just fine. I'm thinking of clearing some telephone wiring messes in my house. What the installers did is enough to make you cry.
InPhase277 11-30-2008 04:48 AM
If all you are doing is standard voice, then the non-twisted stuff is usually OK. It's when higher frequencies are involved, such as data transmission, that the twisted stuff becomes useful.
Gigs 11-30-2008 02:42 PM
I ran my telephone on CAT3 and 4. :P
Maybe you should look around for CAT3 scraps that were abandoned wiring that was removed... you could probably get those nearly free on auction sites. I pulled mine out of the drop ceiling of my employer.
rgsgww 11-30-2008 03:13 PM
This house has a mix of cat 3 and old round cable from 1960 in pvc or fabric insulation.
There are some telephone wire spaghetti messes....
Wildie 11-30-2008 03:37 PM
Flat wire at certain frequencies effectively becomes a short circuit.
For plain old phone use, its not a problem. However, DSL is now used extensively, and probably won't work very well on parallel wire.
When wiring for category 5. the twists must be maintained right up to the terminal and if jumpers are used, the twists must be maintained for these as well.
Twisted telephone wire is not really expensive, so there's little advantage in cutting corners.
