Old 09-23-2012, 09:22 PM   #1
telephone switch in a box
I have no need for a telephone land line, but I have a handful of old Western Electric phones I would like to use. What I want to do is set up in the house it's own telephone switch. Sort of like those office telephone systems where one can call within the buildings with at 3 digit extension or something...only, I have no need to dial 9 to get an outside line, and I want to use ordinary phones. Does anyone know of anybody that makes a small telephone switch, with maybe 3 or 4 lines that will work for this task?
av-geek is offline   Reply With Quote
Old 09-23-2012, 09:46 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Yes, but they are not call switches. The going method is Digital Phone or VoIP. A couple of companies make the Operating system with software, and there are a few companies that make the PC components & shelf type hardware. Linksys used to make hardware for VoIP, but they stopped after it was deemed a Loss Leader.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 09-24-2012, 08:52 AM   #3
joed's Avatar
I doubt a VOIP system would work with old phones. I think they require special phones. At least the system in our office does.
What you want is your own PBX, private branch exchange.
Here is a link I found using google.
http://wandel.ca/homepage/pbx.html
Do not PM with questions that can be asked in a forum. I will not respond.
Old 09-24-2012, 10:27 AM   #4
VOIP is nice, but I don't really need an outside line. I am just looking at say making calls from the bedroom to the basement, or call from the kitchen to the garage (Honey, dinner's ready!) Part of this too is that I have some old Western electric phones that I want to "show off" to visitors...you know, the kind with real bells in them
I've found many old office PBX boxes out there of various types...The AT&T merlin systems can be had a dime a dozen, along with many others, as offices move to VOIP, but the problem with using one of them is that they require proprietary phones. That looks like a fun little project that he's put together there, and it works with regular phones too!
I'm just real surprised nobody builds, or at least I have never found one, a telephone box that allows one to put together a small private telephone network.
Years ago, I remember a family friend had two old crank telephones connected together. One was at his grandmother's house on the other side of the farm, and he had the other one. It had a big battery that sat on the floor. If you wanted to call grandma, you picked up the earpiece and turned the crank. Her phone would ring when you turned the crank and she would answer It was their own "hotline". The cable was strung along the fence around the field...about 800 feet of wire or so between the two houses!
Old 09-24-2012, 01:03 PM   #5
gregzoll's Avatar
What happened to yelling across the house, or actually getting up to find the person. Easier to just go old school.
As for older phones not working with VoIP, they are used all of the time joed.
Old 09-24-2012, 01:50 PM   #6
joed's Avatar
They might be used in a home with a VoIP router connected to the cable system. The router or what ever they call the box does the conversion to POTS. But they are not used in full VOIP system were each phone has its own number unless you add some sort of adapter box to connect to the VOIP system. The phone has to have a MAC address to assign it an IP address.
Old 09-24-2012, 03:59 PM   #7
gregzoll's Avatar
jord, I know how VoIp works. It can actually work both ways. You can use desksrts that receive a IP, or use a PC card interface to allow concentional desksets to be used.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
