Telephone Splice Connectors - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 06:44 AM   #1
Telephone splice connectors
Does anyone have a source for 4 wire telephone splice connectors/IDC type? I'm working behind an electrician that apparently did not understand the "home run" concept. He ran a UTP to the the first telephone jack and ran two wires from that location to other outlets. I have to use a keystone jack at this first location so the jack can only accept one wire. I really don't want to strip and crimp with an insulated crimp but that's looking like the only option right now.
jerryh3 is offline   Reply With Quote
Old 08-22-2009, 10:08 PM   #2
If you don't mind buying online you might try here, http://www.onestopbuy.com/
Don't know if they'll have what you're looking for, but they've got a lot.
oscarMadison is offline   Reply With Quote
Old 08-22-2009, 11:25 PM   #3
DIYer
I would just twist the wires together and tape them. It's just phone...
Gigs is offline   Reply With Quote
Old 08-23-2009, 11:16 AM   #4
Licensed electrician
Rewards Points: 1,892
Do these need to accept 4 wires or are you just splicing a 4 wire cable?
Scotchlock makes UR3 connectors that should work for what you want but they only accept 3 wires.
Old 08-23-2009, 12:28 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it's not wise to think this anymore. DSL is so common that you should consider the possibility that the line may be used for a DSL connection.
Old 08-23-2009, 07:20 PM   #6
I have the three wire Ideal ones. I would have needed four wire ones for what I intended to do. But, I ended up using a regular wall plate that had screw terminals. I was able to land all three wires on the screws and everything worked out.
Opinions of Ideal push-in wire connectors Bigplanz Electrical 62 07-03-2014 10:29 PM
Testing Home Telephone Line kirridam Electrical 4 08-02-2009 07:39 PM
to splice or not to splice treedoc Electrical 4 01-19-2008 10:56 PM
Twin Impeller Shower Pump Connectors snowman23 Plumbing 1 11-11-2007 04:33 AM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 02:21 PM
