Taps Used In Transformers - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 02:44 PM   #1
Taps used in Transformers
In Transformer's what are Taps and when are they used?
e3belectrical is offline   Reply With Quote
Old 02-26-2013, 02:49 PM   #2
Rewards Points: 6,652
Sounds like a home work question. What does your study material or instructor state during class?
Old 02-26-2013, 03:15 PM   #3
Rewards Points: 347
Taps is what I play when a transformer dies.
al_smelter is offline   Reply With Quote
The Following User Says Thank You to al_smelter For This Useful Post:
Dierte (02-26-2013)
Old 02-26-2013, 07:21 PM   #4
Engineer
Rewards Points: 161
Yep, based on the recent posts I'd say the same thing.
diystephen is offline   Reply With Quote
Old 02-26-2013, 07:34 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
So what if it is homework, you think everybody else in the class isn't trying to find out the same thing?
OP there are primary taps and secondary taps. Take a look at how transformers are configured ... use the internet if you want ....
If it still doesn't make since come back and I'll give another hint. My purpose is to get your mind thinking correctly so you can figure it out on your own.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-27-2013, 02:40 AM   #6
Rewards Points: 1,192
Taps on a xfmr are used to adjust the ouput voltage if incoming voltage is high or lower than needed.
bobelectric is offline   Reply With Quote
Old 02-27-2013, 05:42 AM   #7
Rewards Points: 347
I think everyone in the class IS trying to find out the same thing. However, any class I ever took had text books that would readily explain the question. If you will notice, this same OP posted many questions in succession. So, sounds to me like one of two things is happening:
1. He is trying to learn things on his own without text. In that case, if he had explained this scenario, I should think we would all have been much more receptive to these mass postings.
2. He is in a structured class and either doesn't want to, or just didn't, study the course material. So what easier way to get someone else to do your homework than the bloody INTERNET!
To the OP, if you fall under number one above, please explain. I will PM you with many details and source material. If you fall under number two, then crack the book, study and absorb what you can, and then return for much more focused detail of what part you might not understand.
The Following 2 Users Say Thank You to al_smelter For This Useful Post:
gregzoll (02-27-2013), Speedy Petey (02-27-2013)
Old 02-27-2013, 06:03 AM   #8
eastcoastsparky's Avatar
Rewards Points: 150
Dude you about 4 threads all about taps and transformers. If your going to ask a homework question at least keep it discreet or keep them all in one thread
eastcoastsparky is offline   Reply With Quote
The Following User Says Thank You to eastcoastsparky For This Useful Post:
Old 02-27-2013, 07:55 AM   #9
Now of course everything they need to know can be found at http://www.phy.davidson.edu/instrumentation/NEETS.htm Which is the same stuff I had to use to earn my certification in the Navy. The material is written at a sixth grade level, so any 12 year old could even understand the majority of it.
New taps : is it me ? El Bandito Plumbing 3 06-29-2012 09:30 AM
Tub taps vs sink taps Mark Harvey Plumbing 0 04-24-2012 09:51 AM
Timer Switch For 24v Transformers? jesselfout Electrical 12 03-08-2012 04:31 PM
voltage issues assosiated with banked generator transformers? vaddeboina Off Topic 3 03-11-2010 12:26 PM
Eliminating Double Taps in Older Sylvania 200A Panel Reilley Electrical 14 01-11-2009 04:52 PM
