Tapping Into Circuit In Attic? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 10:00 AM   #1
Question
Tapping into circuit in attic?
What is the proper way to tap into an existing circuit in the attic so I can get power to a new ceiling fan? Can someone post a diagram or a link. I also want to add via attic access 2 ceiling lights to a bedroom so I want to tap into a circuit over the bedroom.
christoph is offline   Reply With Quote
Old 03-29-2012, 10:10 AM   #2
Rewards Points: 6,652
Use a junction box. I used my bedroom lighting circuit, when I hooked up my attic vent fan. Keep in mind, that if you are nearing the limits on the 15 amp circuit.
Old 03-29-2012, 10:24 AM   #3
i understand to use a junction box, but what if the wire i'm tapping into does not have enough slack to comfortably do it? what is the best way to add the junction box then?
Old 03-29-2012, 10:26 AM   #4
Licensed electrician
Rewards Points: 1,266
Certain circuits should not be tapped into as they a dedicated to specific usages.
Without enough slack you need to add 2 junction boxes.
christoph (03-29-2012)
Old 03-29-2012, 10:27 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
add two junction boxes and wire between them
Be sure that all power is off in that cable before cutting it.
Old 03-29-2012, 10:28 AM   #6
thats what i thought, ty
Old 03-29-2012, 11:23 AM   #7
joed's Avatar
Rewards Points: 12,010
And be sure of what cable you are cutting into. If the cable happens to be a switch loop, then you can't get power from it. There will be no neutral. Even though there is a white wire it will not be neutral.
The Following User Says Thank You to joed For This Useful Post:
k_buz (03-29-2012)
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 09:10 PM
Attic fan and skylights on same circuit ok? shadango Electrical 7 06-09-2008 03:50 PM
